Pular para o conteúdo principal
Ajuda
Samsung Droid Charge SIM Card Port Replacement
Fotos de ação
Fotos de ação
Seja um herói em ação! Este guia precisa de imagens que melhor demonstrem como executar ações específicas.
Polícia gramatical
Polícia gramatical
Abrace seu professor de Inglês interior e ajude a melhorar a gramática deste guia!
Replace the SIM card slot/port on your Samsung Droid Charge.
  • Autor: Lucas Carter
  • Tempo estimado: 10 minutos
  • Dificuldade: Fácil
This guide will show you how to remove your current SIM card port/slot and replace it with a new one.
Seções
Passo 1 SIM Card Port  ¶
Carefully remove the back cover.
  • Carefully remove the back cover.
  • Locate the 7 small black screws located around the edge of the phone.
  • With a small philips head screwdriver, remove each of the screws, and place them in a secure location.
Passo 2  ¶
Removal of the back half of the casing.
Passo 2  ¶
  • Removal of the back half of the casing.
  • Using a thin plastic flat head screw driver, or similar item. On the side of the phone insert the thin edge into the visible split between the 2 halves of the phone.
  • Use a prying motion to lift the casing up. This will separate the phone casing.
  • Repeat this motion all around the screen edge until the casing pops off.
Passo 3  ¶
Locate and release the volume button flex cable on the right.
Passo 3  ¶
  • Locate and release the volume button flex cable on the right.
  • Locate and release the pop connector on the motherboard located to the left of the SIM card port.
Passo 4  ¶
Your SIM card port is now unattached. Remove SIM card port from motherboard.
Passo 4  ¶
  • Your SIM card port is now unattached.
  • Remove SIM card port from motherboard.
