Pular para o conteúdo principal
Ajuda
HP Mini 210 Hard Drive Replacement
Faltou uma etapa
Faltou uma etapa
Ops! Este guia está faltando alguns passos importantes.
Replace your hard drive so it will function properly.
  • Autor: Heather Freed
  • Tempo estimado: 10 - 20 minutos
  • Dificuldade: Fácil
If the hard drive makes scratching or whining noises, or if the operating system does not boot due to a disk read error, you may need to replace it.
The hard drive contains operating system files and your personal files. If you intend to replace the hard drive, save any personal files you need later onto an alternative media source before completing these steps. You will need to install an operating system on the new hard drive once the new hard drive is installed on the netbook.
Passo 1 Hard Drive  ¶
Peel back the black sticker covering the hard drive with tweezers or your fingers.
  • Peel back the black sticker covering the hard drive with tweezers or your fingers.
Passo 2  ¶
Use a plastic opening tool to carefully disconnect the hard drive connector found above the RAM slot.
Passo 2  ¶
  • Use a plastic opening tool to carefully disconnect the hard drive connector found above the RAM slot.
Passo 3  ¶
Pull the silver plastic tab up and remove the hard drive. The tab may also be black. Be aware of the 4 foam cushions on each corner of the hard drive as they may become loose during removal.
Passo 3  ¶
  • Pull the silver plastic tab up and remove the hard drive. The tab may also be black.
  • Be aware of the 4 foam cushions on each corner of the hard drive as they may become loose during removal.
