Pular para o conteúdo principal
Ajuda
MacBook Air 13" Mid 2012 I/O Board Replacement
Replace the I/O board on your MacBook Air 13" Mid 2012. The I/O board houses the MagSafe DC-in port, a USB socket, and the headphone jack.
Use this guide to replace your Air's I/O board which houses the MagSafe DC-in port, a USB socket, and the headphone jack.
Ferramentas (continuação)
Partes relevantes
Passo 1 I/O Board  ¶
Disconnect the I/O board by pulling the power cable away from its socket on the logic board.
Passo 1 I/O Board  ¶
  • Disconnect the I/O board by pulling the power cable away from its socket on the logic board.
  • Pull the cable parallel to the face of the logic board toward the right edge of the Air.
Passo 2  ¶
Pull the camera cable parallel to the face of the I/O board toward the hinge of the Air to disconnect it from its socket, using the tip of a spudger to help push the connector out of its socket.
Passo 2  ¶
  • Pull the camera cable parallel to the face of the I/O board toward the hinge of the Air to disconnect it from its socket, using the tip of a spudger to help push the connector out of its socket.
  • Do not lift upward on this cable as you disconnect it, as its socket may break off the logic board.
Passo 3  ¶
Use the flat end of a spudger to pry the left speaker cable connector up and out of its socket on the I/O board.
Passo 3  ¶
  • Use the flat end of a spudger to pry the left speaker cable connector up and out of its socket on the I/O board.
  • Pry up from beneath the wires.
Passo 4  ¶
Use the tip of a spudger to flip up the retaining flap securing the microphone ribbon cable to the I/O board. Use the tip of a spudger to remove the volume button ribbon cable from its ZIF connector on the I/O board.
Passo 4  ¶
  • Use the tip of a spudger to flip up the retaining flap securing the microphone ribbon cable to the I/O board.
  • Use the tip of a spudger to remove the volume button ribbon cable from its ZIF connector on the I/O board.
Passo 5  ¶
Remove the single 4.0 mm T5 Torx screw securing the I/O board to the upper case.
Passo 5  ¶
  • Remove the single 4.0 mm T5 Torx screw securing the I/O board to the upper case.
Passo 6  ¶
Carefully lift the I/O board from its edge nearest the logic board and remove it from the upper case.
Passo 6  ¶
  • Carefully lift the I/O board from its edge nearest the logic board and remove it from the upper case.
