Pular para o conteúdo principal
Ajuda
GD Midea FT30-3D Power/Speed Switch Replacement
Fotos de ação
Fotos de ação
Seja um herói em ação! Este guia precisa de imagens que melhor demonstrem como executar ações específicas.
Melhor Introdução
Melhor Introdução
Melhore este guia, completando ou revendo a sua introdução.
This guide will show you how to replace the power/speed switch on the fan
  • Autor: Alan Su
  • Tempo estimado: 5 - 10 minutos
  • Dificuldade: Moderado
Passo 1 Power/Speed Switch  ¶
Remove the two 10 mm Phillips #1 screws found connecting the switch to the case.
  • Remove the two 10 mm Phillips #1 screws found connecting the switch to the case.
  • Notice the AC power cord line (white wire) goes into the switch under the [Off] button
Passo 2  ¶
Take the 1.5 mm Flathead Screwdriver, or any thin elongated tool that fits into the semi-circular holes along side the wires. Press into the hole gently to release the grip on the wires.
Passo 2  ¶
  • Take the 1.5 mm Flathead Screwdriver, or any thin elongated tool that fits into the semi-circular holes along side the wires. Press into the hole gently to release the grip on the wires.
  • The wires should release with ease if done properly.
  • When reassembling; skip this step.
Passo 3  ¶
Take the new switch, and simply push the wiring into the correct holes:
Passo 3  ¶
  • Take the new switch, and simply push the wiring into the correct holes:
  • AC Power Cord (white wire)
  • Low speed (gray wire)
  • Medium speed (orange wire)
  • High speed (red wire)
