Pular para o conteúdo principal
Ajuda
Mac mini Model A1176 Optical Drive Replacement
Upgrade or replace the combo or SuperDrive.
Passo 1 Optical Drive  ¶
The Bluetooth antenna is removed by simply lifting it up off the internal frame.
  • The Bluetooth antenna is removed by simply lifting it up off the internal frame.
  • Remove the Bluetooth antenna from the internal frame by pushing up on both sides of the board as close to the center post as possible.
  • This may require a bit of force.
Passo 2  ¶
Remove the two Phillips screws securing the optical drive to the internal frame.
Passo 2  ¶
  • Remove the two Phillips screws securing the optical drive to the internal frame.
Passo 3  ¶
Turn the mini 180 degrees and remove the two Phillips screws securing the optical drive to the internal frame on the other side.
Passo 3  ¶
  • Turn the mini 180 degrees and remove the two Phillips screws securing the optical drive to the internal frame on the other side.
Passo 4  ¶
Remove the two Phillips screws securing the interconnect board to the optical drive.
Passo 4  ¶
  • Remove the two Phillips screws securing the interconnect board to the optical drive.
Passo 5  ¶
Use the flat end of a spudger to separate the interconnect board from the optical drive.
Passo 5  ¶
  • Use the flat end of a spudger to separate the interconnect board from the optical drive.
Passo 6  ¶
Lift the optical drive out of the internal frame.
Passo 6  ¶
  • Lift the optical drive out of the internal frame.
