Pular para o conteúdo principal
Ajuda
Raleigh M20 Seat Cushion Replacement
This guide allow the user to easily replace a seat cushion in only four steps.
  • Autor: Dante Bozzini
  • Tempo estimado: 10 minutos
  • Dificuldade: Fácil
This guide will give a step by step walkthrough of how to replace an old seat cushion with a new one.
Ferramentas
Partes relevantes
Passo 1 Seat Cushion  ¶
Loosen the seat clamp by pulling the black lever away from the frame. Once this is done, simply rotate the lever counter-clockwise to loosen the seat. Stand on the right side of the bike while loosening the lever and make sure  the bike isn't upside-down. This will prevent the seat from falling off during this process. Stand on the right side of the bike while loosening the lever and make sure  the bike isn't upside-down. This will prevent the seat from falling off during this process.
  • Loosen the seat clamp by pulling the black lever away from the frame. Once this is done, simply rotate the lever counter-clockwise to loosen the seat.
  • Stand on the right side of the bike while loosening the lever and make sure the bike isn't upside-down. This will prevent the seat from falling off during this process.
Passo 2  ¶
Now that the seat is loosened, slowly pull up on the seat cushion until it is fully out of the frame. Next, place the seat on the ground. Now that the seat is loosened, slowly pull up on the seat cushion until it is fully out of the frame. Next, place the seat on the ground.
Passo 2  ¶
  • Now that the seat is loosened, slowly pull up on the seat cushion until it is fully out of the frame. Next, place the seat on the ground.
Passo 3  ¶
Use an Allen wrench to unscrew the bolt that is holding the post to the seat cushion. Use an Allen wrench to unscrew the bolt that is holding the post to the seat cushion.
Passo 3  ¶
  • Use an Allen wrench to unscrew the bolt that is holding the post to the seat cushion.
Passo 4  ¶
Now that the bolt is loosened, carefully pull the seat cushion from the post. Next remove the two riders as shown in the second image. Now that the bolt is loosened, carefully pull the seat cushion from the post. Next remove the two riders as shown in the second image. Now that the bolt is loosened, carefully pull the seat cushion from the post. Next remove the two riders as shown in the second image.
Passo 4  ¶
  • Now that the bolt is loosened, carefully pull the seat cushion from the post. Next remove the two riders as shown in the second image.
