Pular para o conteúdo principal
Ajuda
iBook G3 Clamshell Modem Replacement
  • Autor: iRobot
  • Dificuldade: Moderado
56k internal modem, standard on all models.
Seções
Arquivos
Passo 1 Modem  ¶
Remove the following Phillips screws:
Passo 1 Modem  ¶
  • Remove the following Phillips screws:
  • Remove the longer Phillips screw from the middle-rear of the modem shield.
  • Remove the three identical Phillips screws, two on either side of the EMI fingers, and the remaining one on the right side of the modem shield.
  • Remove the larger Phillips screw that secures the EMI fingers to the modem board.
  • Remove the EMI fingers.
Passo 2  ¶
Peel the modem shield away from the metal framework below, working from the right front and moving to the left.
Passo 2  ¶
  • Peel the modem shield away from the metal framework below, working from the right front and moving to the left.
Passo 3  ¶
Remove the Phillips screw from the left side of the modem.
Passo 3  ¶
  • Remove the Phillips screw from the left side of the modem.
  • Pry up the right side of the modem.
Passo 4  ¶
Lift the modem partially out and disconnect the cable on the left side.
Passo 4  ¶
  • Lift the modem partially out and disconnect the cable on the left side.
