Pular para o conteúdo principal
Ajuda
Garmin GPSmap 60CSx Battery Terminal Replacement
How to change a broken battery terminal on a Garmin GPSmap 60CSx.
If you know your batteries are not the problem, but your device will not power on, your battery terminals may be corroded. The following is a guide on how to replace battery terminals on the Garmin GPSmap 60CSx.
Seções
Ferramentas
  • Spudger Any small stick spudger can work. The one used in this guide is from the iFixit Pro Tech Tool Kit Buy it
  • Metal Spudger Any metal spudger will work. The one used in this guide is from the iFixit Pro Tech Tool Kit Buy it
  • Phillips #0 Screwdriver Buy it
Passo 1 Battery Terminals  ¶
Remove the six 10 mm screws on the back of the device with a Phillips #0 Screwdriver.
  • Remove the six 10 mm screws on the back of the device with a Phillips #0 Screwdriver.
Passo 2  ¶
Place spudger behind the lower right battery terminal. Push spudger behind the battery terminal to pop it out of place.
Passo 2  ¶
  • Place spudger behind the lower right battery terminal.
  • Push spudger behind the battery terminal to pop it out of place.
  • Now do the same on the bottom left side.
Passo 3  ¶
Grab the now loose battery terminals and pull them from the GPSMap 60CSx. Grab the now loose battery terminals and pull them from the GPSMap 60CSx.
Passo 3  ¶
  • Grab the now loose battery terminals and pull them from the GPSMap 60CSx.
Passo 4  ¶
Flip the back panel over to expose the backs of the top battery terminals. Use a metal spudger to remove the glue that covers them.
Passo 4  ¶
  • Flip the back panel over to expose the backs of the top battery terminals.
  • Use a metal spudger to remove the glue that covers them.
Passo 5  ¶
Flip the back panel back over to view the battery compartment. Place the spudger behind one of the top remaining battery terminals.
Passo 5  ¶
  • Flip the back panel back over to view the battery compartment.
  • Place the spudger behind one of the top remaining battery terminals.
  • Push the spudger down and pop the battery terminal out of place.
  • Repeat with the remaining battery terminal.
