Pular para o conteúdo principal
Ajuda
Keurig 2.0-400 Water Reservoir Replacement
After reading this guide, you will be able to replace the tank that holds water.
  • Autor: Alec Jamosmos
  • Tempo estimado: 30 segundos
  • Dificuldade: Muito fácil
In this guide, you will replace the water reservoir. This is necessary if you want to clean the reservoir or if it does not hold water sufficiently. The water reservoir is transparent and is located on the left side of the Keurig machine.
Passo 1 Water Reservoir  ¶
Locate and grab the Water Reservoir with your hands.
  • Locate and grab the Water Reservoir with your hands.
Passo 2  ¶
Lift the Water Reservoir up.  It should be easy to separate it from the main part of the brewer. Lift the Water Reservoir up.  It should be easy to separate it from the main part of the brewer. Lift the Water Reservoir up.  It should be easy to separate it from the main part of the brewer.
Passo 2  ¶
  • Lift the Water Reservoir up. It should be easy to separate it from the main part of the brewer.
