Pular para o conteúdo principal
Ajuda
Wolf Gourmet WGBL100S Blades Replacement
Guia do aluno destaque
Este guia tem sido o trabalho duro de nossos alunos incríveis e é considerado extremamente bacana pelo equipe da iFixit.
This is a guide for the replacement of blades in the Wolf Gourmet High-Performance Blender.
  • Autor: Luke Kutz
  • Tempo estimado: 10 - 15 minutos
  • Dificuldade: Moderado
If your blender is not chopping food correctly, consider replacing the blades. The blades can be very sharp, so please take caution when proceeding with this guide.
Passo 1 Blender Blades  ¶
Flip over the pitcher to expose the base of the blade assembly.
  • Flip over the pitcher to expose the base of the blade assembly.
  • Using the H4.0 Allen key from the 54 bit driver kit, attached to an impact driver, remove the socket head cap screw from the drive coupling.
  • Apply a solvent to remove adhesive if necessary.
Passo 2  ¶
Using a pair of pliers, pull of the drive shaft coupling.
Passo 2  ¶
  • Using a pair of pliers, pull of the drive shaft coupling.
Passo 3  ¶
Using a flat head screwdriver and a mallet, bend down the two tabs holding the large nut. Using a flat head screwdriver and a mallet, bend down the two tabs holding the large nut.
Passo 3  ¶
  • Using a flat head screwdriver and a mallet, bend down the two tabs holding the large nut.
Passo 4  ¶
Remove the nut using a crescent wrench.
Passo 4  ¶
  • Remove the nut using a crescent wrench.
Passo 5  ¶
Push the blade assembly into the jar.
Passo 5  ¶
  • Push the blade assembly into the jar.
  • Remove the blades from the device.
  • Be careful not to cut yourself when handling the blades.
