Pular para o conteúdo principal
Ajuda
Yuneec Typhoon H Spring Clip Replacement
Replace your broken arm clip or spring clip to allow for arm movement again.
  • Autor: Claire Luce
  • Tempo estimado: 5 - 10 minutos
  • Dificuldade: Moderado
The guide instructs you to replace the spring clip or (also known as the arm clip) at the arm attachment on the Yuneec Typhoon H.
The spring clips usually get broken during a crash.
Passo 1 Spring Clip  ¶
Using a JIS #00 screwdriver, unscrew the 3mm oval screw. The oval screw is hard to remove once fully unscrewed, to remove the screw flip the drone upside down to have the screw fall out. The oval screw is hard to remove once fully unscrewed, to remove the screw flip the drone upside down to have the screw fall out.
  • Using a JIS #00 screwdriver, unscrew the 3mm oval screw.
  • The oval screw is hard to remove once fully unscrewed, to remove the screw flip the drone upside down to have the screw fall out.
Passo 2  ¶
For this step the arm must be bent. Remove the broken arm clip by pinching the metal top and then pull it out with an upward force.
Passo 2  ¶
  • For this step the arm must be bent.
  • Remove the broken arm clip by pinching the metal top and then pull it out with an upward force.
  • The Blunt Nose Tweezers may be helpful in removing the arm clip.
