Pular para o conteúdo principal
Ajuda
Sony Xperia XA1 Ultra Motherboard Replacement
A replacement guide for the Sony Xperia XA1 Ultra motherboard.
  • Autor: Jacob Jung
  • Tempo estimado: 15 minutos
  • Dificuldade: Moderado
This guide will show you how to remove the motherboard from your Sony Xperia XA1 Ultra. The motherboard may need to be replaced if basic functions of the phone no longer run. A heat gun or hairdryer is needed to open the back panel, which can become hot and potentially damage the phone. Additonally, a T5 screwdriver is needed to remove screws while a spudger is needed to disconnect parts of the phone.
Seções
Passo 1 Motherboard  ¶
Remove the two 4mm T5 screws connecting the motherboard to the device. Remove the two 4mm T5 screws connecting the motherboard to the device.
  • Remove the two 4mm T5 screws connecting the motherboard to the device.
Passo 2  ¶
Use your flat head tweezers to remove the black wire connected to the motherboard. Use your flat head tweezers to remove the white wire connected to the motherboard. There are only two wires connected to the motherboard.
Passo 2  ¶
  • Use your flat head tweezers to remove the black wire connected to the motherboard.
  • Use your flat head tweezers to remove the white wire connected to the motherboard.
  • There are only two wires connected to the motherboard.
Passo 3  ¶
Use your iFixit Opening Tool to remove the main flex (the middle orange tab) from the motherboard. Use your iFixit Opening Tool to remove the power button flex (the left orange tab) from the motherboard. Use your iFixit Opening Tool to remove the power button flex (the left orange tab) from the motherboard.
Passo 3  ¶
  • Use your iFixit Opening Tool to remove the main flex (the middle orange tab) from the motherboard.
  • Use your iFixit Opening Tool to remove the power button flex (the left orange tab) from the motherboard.
Passo 4  ¶
Wedge your iFixit opening tool under the motherboard. Lift up with your iFixit Opening Tool to lift the motherboard from the device.
Passo 4  ¶
  • Wedge your iFixit opening tool under the motherboard.
  • Lift up with your iFixit Opening Tool to lift the motherboard from the device.
