Pular para o conteúdo principal
Ajuda
Sony Xperia XA1 Ultra Loudspeaker Replacement
A replacement guide for the Sony Xperia XA1 Ultra loudspeaker.
  • Autor: Jacob Jung
  • Tempo estimado: 7 minutos
  • Dificuldade: Fácil
This guide will show you how to remove the loudspeaker from your Sony Xperia XA1 Ultra. The loudspeaker needs to be replaced if sound is no longer emitted from your phone. A heat gun or hairdryer is needed to open the back panel, which can become hot and potentially damage the phone. In addition, a T5 screwdriver is needed to remove screws, and a spudger is used to lift and remove components of the phone.
Passo 1 Loudspeaker  ¶
Remove the five 4mm T5 screws connecting the speaker to your phone.
  • Remove the five 4mm T5 screws connecting the speaker to your phone.
Passo 2  ¶
Insert your iFixit Opening Tool underneath the speaker and gently lift up. Once the speaker is slightly lifted, use your hands to remove the piece from the device.
Passo 2  ¶
  • Insert your iFixit Opening Tool underneath the speaker and gently lift up.
  • Once the speaker is slightly lifted, use your hands to remove the piece from the device.
