Pular para o conteúdo principal
Ajuda
Acer Aspire ES1-711-P1UV Fan Replacement
Guia do aluno destaque
Este guia tem sido o trabalho duro de nossos alunos incríveis e é considerado extremamente bacana pelo equipe da iFixit.
This guide will teach you how to replace the fan from your Acer Aspire ES1-711-P1UV.
This replacement guide will teach the reader the proper way to remove the fan from their Acer Aspire ES1-711-P1UV. If the laptop is consistently getting too hot on the bottom or is making loud sounds that resemble that of a fan, the fan may need to be replaced. The fan serves to cool down the computer to prevent overheating. If the laptop gets too hot, it may shut down or damage the other mechanics.
Passo 1 Fan  ¶
Locate and remove the 5 mm screw using the Phillips #0 screwdriver.
Passo 1 Fan  ¶
  • Locate and remove the 5 mm screw using the Phillips #0 screwdriver.
  • Unscrew the four 5mm screws still holding down the fan.
  • The four 5mm screws in the second part of this step cannot be fully removed from the fan. Loosen them and continue on to Step 6.
Passo 2  ¶
Disconnect the red, white, black, and yellow bundled cable connectors from the motherboard by gently pulling them. Remove the fan assembly. Remove the fan assembly.
Passo 2  ¶
  • Disconnect the red, white, black, and yellow bundled cable connectors from the motherboard by gently pulling them.
  • Remove the fan assembly.
