Pular para o conteúdo principal
Ajuda
Mac mini Model A1283 Speaker Replacement
Restore sound to your mini by replacing the speaker.
Seções
Passo 1 Speaker  ¶
Disconnect the speaker cable connector from the interconnect board by lifting its connector up off the socket on the board.
Passo 1 Speaker  ¶
  • Disconnect the speaker cable connector from the interconnect board by lifting its connector up off the socket on the board.
Passo 2  ¶
Use the tip of a spudger to de-route the speaker cable from the clip on the internal frame.
Passo 2  ¶
  • Use the tip of a spudger to de-route the speaker cable from the clip on the internal frame.
Passo 3  ¶
De-route the speaker cable from within the channel in the internal frame.
Passo 3  ¶
  • De-route the speaker cable from within the channel in the internal frame.
Passo 4  ¶
Remove the four shouldered Phillips screws securing the speaker assembly to the internal frame.
Passo 4  ¶
  • Remove the four shouldered Phillips screws securing the speaker assembly to the internal frame.
Passo 5  ¶
Lift the speaker out of the internal frame.
Passo 5  ¶
  • Lift the speaker out of the internal frame.
  • During reassembly, be sure to thread the speaker cable through the opening in the internal frame before fastening the screws down.
