Pular para o conteúdo principal
Ajuda
Asus Rog GL55VW-DH71 USB port Replacement
This guide will show how to replace the USB module, in the event that you have a port that is inoperable.
This guide will teach you how to remove and replace the USB module in the event that it doesn't work properly. Special care must be taken, due to the delicate parts and ribbon cables needed to be removed during the repair.
Passo 1 USB port  ¶
The pictures shown are taken with the motherboard removed. This is not required for the replacement of the USB module. Remove the two 2.8mm Phillips #00 screws.
Passo 1 USB port  ¶
  • The pictures shown are taken with the motherboard removed. This is not required for the replacement of the USB module.
  • Remove the two 2.8mm Phillips #00 screws.
  • Carefully remove the ZIF connector ribbon cable from the module by lifting up on the latch and pulling the cable out.
