Ajuda
DBPOWER T20 Lamp Replacement
Melhor Introdução
Melhor Introdução
Melhore este guia, completando ou revendo a sua introdução.
If you are noticing bad image quality you may need to replace the lamp. This guide will help you access the lamp in the projector for easy replacement.
Simply pull the lamp out once you remove the screws. This should not require much force so if the lamp is not coming out, make sure you took out all the screws in the steps leading up to the removal.
Passo 1 Lamp  ¶
Remove the two screws attached to the lamp with a J0 screwdriver.
Passo 1 Lamp  ¶
  • Remove the two screws attached to the lamp with a J0 screwdriver.
Passo 2  ¶
Lift upwards to remove the lamp.
Passo 2  ¶
  • Lift upwards to remove the lamp.
