Pular para o conteúdo principal
Ajuda
Gateway P-6831FX Battery Replacement
This guide will go over how to remove and replace the battery for the P-6831FX.
  • Autor: Justin Freitas
  • Tempo estimado: 4 - 5 minutos
  • Dificuldade: Muito fácil
The battery is a component that will power your device. This guide will go over how to remove and replace the battery for the P-6831FX.
Passo 1 Battery  ¶
Turn your laptop upside down and locate the 1st unlocking switch.
Passo 1 Battery  ¶
  • Turn your laptop upside down and locate the 1st unlocking switch.
  • Make sure to unplug your laptop charger, as removing the battery while the device is charging may damage the battery and or the charger.
Passo 2  ¶
Put the switch from the locked position to the unlocked position. Put the switch from the locked position to the unlocked position.
Passo 2  ¶
  • Put the switch from the locked position to the unlocked position.
Passo 3  ¶
Slide the lock to the right to unlock the battery from the device. Slide the lock to the right to unlock the battery from the device.
Passo 3  ¶
  • Slide the lock to the right to unlock the battery from the device.
Passo 4  ¶
While holding the 2nd lock in the unlocked position, pull the battery away from the laptop. While holding the 2nd lock in the unlocked position, pull the battery away from the laptop.
Passo 4  ¶
  • While holding the 2nd lock in the unlocked position, pull the battery away from the laptop.
