Pular para o conteúdo principal
Ajuda
Protocol Kaptur GPS Main Circuit Board Replacement
Acidente de Marcação
Este guia precisa de melhores marcações. Ajude corrigindo ou fazendo algumas marcações.
Guide on how to access and replace the main circuit board of the Protocol Kaptur GPS drone.
  • Autor: Connor Woitte
  • Tempo estimado: 20 - 30 minutos
  • Dificuldade: Difícil
Passo 1 Main Circuit Board  ¶
Remove the 4x 7mm screws on the top and bottom, and the 2x 5mm screws from the middle,  then remove the back part of the housing. Remove the two hidden screws at the bottom, and the white power button.
  • Remove the 4x 7mm screws on the top and bottom, and the 2x 5mm screws from the middle, then remove the back part of the housing.
  • Remove the two hidden screws at the bottom, and the white power button.
  • There will be 6x 7 mm Phillips head screws, and 2x 5 mm Phillips head screws.
Passo 2  ¶
Unplug all the cords from the circuit boards. Carefully slide the main body off of the arms. Carefully slide the main body off of the arms.
Passo 2  ¶
  • Unplug all the cords from the circuit boards.
  • Carefully slide the main body off of the arms.
Passo 3  ¶
Remove the four screws, and unsolder all cords on the circuit board. There will be 4x 4mm Phillips head screws.
Passo 3  ¶
  • Remove the four screws, and unsolder all cords on the circuit board.
  • There will be 4x 4mm Phillips head screws.
  • It is important to keep track of where the leads came from. Red/Blue and Black/White pairings belong to motors, whereas Black/Red pairings belong to lights. The ports are labeled on the board.
