Pular para o conteúdo principal
Ajuda
Toshiba Satellite C55D-B5310 Fan Replacement
How to replace the fan in a Toshiba Satellite C55D-B5310.
If the fan is excessively noisy or non-operational, use this guide to remove and replace the fan.
Passo 1 Fan  ¶
Remove the remaining thirteen 7 mm Phillips screws holding the back cover  using the PH1 bit and Magnetic Driver.
Passo 1 Fan  ¶
  • Remove the remaining thirteen 7 mm Phillips screws holding the back cover using the PH1 bit and Magnetic Driver.
Passo 2  ¶
Using the plastic opening tools, separate the back cover from the laptop. It is recommended that you start from a corner and run the tool along the edge of the cover.
Passo 2  ¶
  • Using the plastic opening tools, separate the back cover from the laptop.
  • It is recommended that you start from a corner and run the tool along the edge of the cover.
  • Be careful not to bend or crack the plastic back cover.
Passo 3  ¶
Remove the three 3 mm Phillips screws holding the fan cable in place using the PH1 bit and Magnetic Driver. Lift the fan cable connector from the fan. Lift the fan cable connector from the fan.
Passo 3  ¶
  • Remove the three 3 mm Phillips screws holding the fan cable in place using the PH1 bit and Magnetic Driver.
  • Lift the fan cable connector from the fan.
Passo 4  ¶
Remove the fan from the plug by releasing the clamps located on each side of the socket. Slide the connector out of the socket. Lift the computer fan from the motherboard.
Passo 4  ¶
  • Remove the fan from the plug by releasing the clamps located on each side of the socket.
  • Slide the connector out of the socket.
  • Lift the computer fan from the motherboard.
