Pular para o conteúdo principal
Ajuda
HP Pavilion 15-ab243cl Battery Replacement
Replace HP battery to power the HP Pavilion 15-ab243cl Notbook Laptop.
  • Autor: Martic Smith
  • Tempo estimado: 1 minuto
  • Dificuldade: Muito fácil
The HP notebook 15 battery can become obsolete over time. This is a guide for its removal and replacement.
Passo 1 Battery  ¶
Slide the battery lock tab toward the center of the battery to the unlock position. Slide the battery lock tab toward the center of the battery to the unlock position.
Passo 1 Battery  ¶
  • Slide the battery lock tab toward the center of the battery to the unlock position.
Passo 2  ¶
Slide the battery release switch to the right until the battery pops out. Slide the battery release switch to the right until the battery pops out. Slide the battery release switch to the right until the battery pops out.
Passo 2  ¶
  • Slide the battery release switch to the right until the battery pops out.
Passo 3  ¶
Grabbing the top edge of the battery, rotate it toward you and then lift upward to relieve the battery from its slot. Grabbing the top edge of the battery, rotate it toward you and then lift upward to relieve the battery from its slot.
Passo 3  ¶
  • Grabbing the top edge of the battery, rotate it toward you and then lift upward to relieve the battery from its slot.
