Pular para o conteúdo principal
Ajuda
Toshiba Satellite C55-B5200 Keyboard Replacement
  • Autor: Pablo Andrade
  • Tempo estimado: 10 minutos
  • Dificuldade: Difícil
Standard Keyboard with 10-key and touchpad with multi-touch control
Passo 1 Keyboard  ¶
Remove the thirteen 6.6mm Phillips #0 screws on the back of the device.
Passo 1 Keyboard  ¶
  • Remove the thirteen 6.6mm Phillips #0 screws on the back of the device.
Passo 2  ¶
Use a plastic opening tool to lift and remove the bottom panel.
Passo 2  ¶
  • Use a plastic opening tool to lift and remove the bottom panel.
Passo 3  ¶
Remove the six 2.3mm Phillips #0 screws from the motherboard.
Passo 3  ¶
  • Remove the six 2.3mm Phillips #0 screws from the motherboard.
  • Use a pair of tweezers to lift up the tab on the ZIF connector and pull out the ribbon cable.
Passo 4  ¶
Disconnect the wires from the motherboard. Lift and remove the disk drive. Lift and remove the hard drive.
Passo 4  ¶
  • Disconnect the wires from the motherboard.
  • Lift and remove the disk drive.
  • Lift and remove the hard drive.
Passo 5  ¶
Lift up the motherboard
Passo 5  ¶
  • Lift up the motherboard
  • Use tweezers to carefully peel apart IDE ribbon cables connected from motherboard to keyboard
Passo 6  ¶
Use a plastic opening tool to unlatch the keyboard from the device Lift the keyboard off the laptop, careful of the IDE ribbon cable
Passo 6  ¶
  • Use a plastic opening tool to unlatch the keyboard from the device
  • Lift the keyboard off the laptop, careful of the IDE ribbon cable
