Pular para o conteúdo principal
Ajuda
Samsung UBD-KM85C WiFi Module Replacement
Whenever the WiFi is not connecting to the device over multiple attempts, then it may be the WiFi Module that will need to be replaced.
  • Autor: James Edwards
  • Tempo estimado: 10 - 15 minutos
  • Dificuldade: Fácil
Use this guide to remove the Wi-Fi module from your device.
Seções
Ferramentas
Passo 1 WiFi Module  ¶
The wifi module is clipped into place in the corner of the device. There are no screws or adhesives holding it down. The wifi module is clipped into place in the corner of the device. There are no screws or adhesives holding it down.
  • The wifi module is clipped into place in the corner of the device. There are no screws or adhesives holding it down.
Passo 2  ¶
There is one wire plugged into the Wi-Fi module that has to be removed in order to allow the range of motion to remove the module. Simply pinch the white plastic end of the wire and pull it out. There is one wire plugged into the Wi-Fi module that has to be removed in order to allow the range of motion to remove the module. Simply pinch the white plastic end of the wire and pull it out. There is one wire plugged into the Wi-Fi module that has to be removed in order to allow the range of motion to remove the module. Simply pinch the white plastic end of the wire and pull it out.
Passo 2  ¶
  • There is one wire plugged into the Wi-Fi module that has to be removed in order to allow the range of motion to remove the module. Simply pinch the white plastic end of the wire and pull it out.
Passo 3  ¶
Pull on the module from the sides and be sure not to pull on the stand that is screwed into the frame. The Wi-Fi module can then be pulled out of the clips and off the stand. Pull on the module from the sides and be sure not to pull on the stand that is screwed into the frame. The Wi-Fi module can then be pulled out of the clips and off the stand. Pull on the module from the sides and be sure not to pull on the stand that is screwed into the frame. The Wi-Fi module can then be pulled out of the clips and off the stand.
Passo 3  ¶
  • Pull on the module from the sides and be sure not to pull on the stand that is screwed into the frame. The Wi-Fi module can then be pulled out of the clips and off the stand.
