Pular para o conteúdo principal
Ajuda
Dell Alienware 14 Power-Adapter Port Replacement
Guia contribuído por membro
Um membro impressionante de nossa comunidade fez este guia. Não é gerenciado pela equipe iFixit.
Follow this guide to replace the Power port adapter for the Dell Alienware 14.
In this guide, we will show you how to remove and replace the Power-Adapter Port.
Seções
Ferramentas
Passo 1 Disconnecting the Tron-Light Cable  ¶
WARNING:  Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer.    After working inside your computer, follow the instructions in After Working Inside Your Computer.
Passo 2 Disconnect the Tron Light  ¶
Disconnect the tron light from the optical fibre.
  • Disconnect the tron light from the optical fibre.
Passo 3 Remove the Screw  ¶
Remove the screw that secures the power-adapter port bracket to the computer base.
  • Remove the screw that secures the power-adapter port bracket to the computer base.
Passo 4 Lift the Power-Adapter Port  ¶
Lift the power-adapter port bracket and keep it aside.
  • Lift the power-adapter port bracket and keep it aside.
Passo 5 Disconnecting the Power-Adapter Port Cable  ¶
Disconnect the power-adapter port cable from the system-board connector.
  • Disconnect the power-adapter port cable from the system-board connector.
Passo 6 Lifting the Power-Adapter Port  ¶
Lift the power-adapter port off the computer base.
  • Lift the power-adapter port off the computer base.
Passo 7 Align the Power-Adapter Port  ¶
Align the NEW power-adapter port with the slot on the computer base and slide the power-adapter port into place.
  • Align the NEW power-adapter port with the slot on the computer base and slide the power-adapter port into place.
Passo 8 Connect the Power-Adapter Port Cable  ¶
Connect the power-adapter port cable to the system-board connector.
  • Connect the power-adapter port cable to the system-board connector.
Passo 9 Align the Screw Hole  ¶
Align the screw hole on the power-adapter port bracket with the screw hole on the computer base. Align the screw hole on the power-adapter port bracket with the screw hole on the computer base.
  • Align the screw hole on the power-adapter port bracket with the screw hole on the computer base.
Passo 10 Replace the Screw  ¶
Replace the screw that secures the power-adapter port bracket to the computer base.
  • Replace the screw that secures the power-adapter port bracket to the computer base.
Passo 11 Connect the Tron Light  ¶
Connect the tron light to the optical fibre.
  • Connect the tron light to the optical fibre.
Passo 12 Connect the Tron-Light Cable  ¶
Connect the tron-light cable to the system-board connector.
  • Connect the tron-light cable to the system-board connector.
