Pular para o conteúdo principal
Ajuda
Lenovo Thinkpad E540 Keyboard Replacement
A guide on how to replace the individual keys on a Lenovo ThinkPad E540 laptop.
  • Autor: Timothy Sumner
  • Tempo estimado: 5 - 15 minutos
  • Dificuldade: Moderado
Seções
Ferramentas
Passo 1 Keyboard  ¶
Push the keyboard forward towards the display to create a gap above the trackpad.
Passo 1 Keyboard  ¶
  • Push the keyboard forward towards the display to create a gap above the trackpad.
Passo 2  ¶
Remove the four 1mm Phillips #00 screws found hidden underneath the keys.
Passo 2  ¶
  • Remove the four 1mm Phillips #00 screws found hidden underneath the keys.
Passo 3  ¶
Tilt the keyboard forward from the top and lift gently.
Passo 3  ¶
  • Tilt the keyboard forward from the top and lift gently.
  • Dont pull too far because there is a cable attached to the back.
Passo 4  ¶
Use a spudger to lift the black latch on the ZIF connectors. Remove the blue and purple ribbon cables from the ZIF connectors.
Passo 4  ¶
  • Use a spudger to lift the black latch on the ZIF connectors.
  • Remove the blue and purple ribbon cables from the ZIF connectors.
