Pular para o conteúdo principal
Ajuda
PowerBook G4 Aluminum 17" 1.67 GHz (High-Res) Battery Replacement
  • Autor: Walter Galan
  • Tempo estimado: 10 segundos
  • Dificuldade: Muito fácil
Replace a worn out battery for longer intervals between recharging.
Passo 1 Battery  ¶
Use your thumbs to push the two battery retaining tabs away from the battery. The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
Passo 1 Battery  ¶
  • Use your thumbs to push the two battery retaining tabs away from the battery.
  • The battery should pop up enough to rotate it toward yourself and lift it out of the lower case.
