Pular para o conteúdo principal
Ajuda
Shark Steam Pocket Mop Water Tank / Bladder Replacement
Fotos de ação
Fotos de ação
Seja um herói em ação! Este guia precisa de imagens que melhor demonstrem como executar ações específicas.
Melhor Introdução
Melhor Introdução
Melhore este guia, completando ou revendo a sua introdução.
This guide will inform users how to replace their Shark Steam Pocket Mop's Water Tank / Bladder.
Passo 1 Water Tank / Bladder  ¶
Start by gently moving the midframe from the top portion of the panel to expose the bottom portion of the mop's water tank / bladder. Start by gently moving the midframe from the top portion of the panel to expose the bottom portion of the mop's water tank / bladder.
  • Start by gently moving the midframe from the top portion of the panel to expose the bottom portion of the mop's water tank / bladder.
Passo 2  ¶
Remove the 10 quarter inch phillips head screws from the bottom portion of the water tank / bladder. Then gently lift the water tank / bladder out of its plastic housing. and turn it over. To fully remove the water tank / bladder, use your tweezers to remove the metal ring that keeps the hose fastened to the plastic tank.
Passo 2  ¶
  • Remove the 10 quarter inch phillips head screws from the bottom portion of the water tank / bladder.
  • Then gently lift the water tank / bladder out of its plastic housing. and turn it over.
  • To fully remove the water tank / bladder, use your tweezers to remove the metal ring that keeps the hose fastened to the plastic tank.
