Pular para o conteúdo principal
Ajuda
Acer Aspire 4520-5464 Keyboard Replacement
How to replace the keyboard of an Acer Aspire 4520-5464 laptop.
This guide will show you how to replace the keyboard of an Acer Aspire 4520-5464 laptop. The keyboard is used to type and use commands on the laptop.
Passo 1 Keyboard  ¶
Remove the five 1mm Phillips #1 screws located inside of the battery compartment.
Passo 1 Keyboard  ¶
  • Remove the five 1mm Phillips #1 screws located inside of the battery compartment.
  • Remove the three 2mm Phillips #1 screws located at the top of the case's perimeter.
Passo 2  ¶
Remove the gray plastic section located above the keyboard using the prying tool. Lift off of the keyboard.
Passo 2  ¶
  • Remove the gray plastic section located above the keyboard using the prying tool.
  • Lift off of the keyboard.
Passo 3  ¶
Take hold of the keyboard behind the function keys and lift gently. Do not completely separate the keyboard from the laptop.
Passo 3  ¶
  • Take hold of the keyboard behind the function keys and lift gently.
  • Do not completely separate the keyboard from the laptop.
Passo 4  ¶
Lift up the black locking tab located where the keyboard is attached to the laptop. Pull the keyboard cable towards the trackpad and remove the keyboard.
Passo 4  ¶
  • Lift up the black locking tab located where the keyboard is attached to the laptop.
  • Pull the keyboard cable towards the trackpad and remove the keyboard.
