Pular para o conteúdo principal
Ajuda
Bose Soundlink Revolve AUX/USB Port Replacement
Replace your damaged AUX/USB port to allow your Soundlink Revolve to charge and directly connect to an audio device again.
  • Autor: Brian Butner
  • Tempo estimado: 20 - 25 minutos
  • Dificuldade: Moderado
Use this guide to replace the AUX/USB port in your device.
Passo 1 AUX/USB Port  ¶
Using the blue plastic opening tool, pry up the small black clamp connecting the AUX/USB port to the lower circuit board. Remove the AUX/USB port from the device. Remove the AUX/USB port from the device.
  • Using the blue plastic opening tool, pry up the small black clamp connecting the AUX/USB port to the lower circuit board.
  • Remove the AUX/USB port from the device.
