Pular para o conteúdo principal
Ajuda
Asus X501A-RH31 Fan Replacement
Locate and replace the fan inside of Asus X501A-RH31 laptop.
  • Autor: Christopher
  • Tempo estimado: 30 minutos
  • Dificuldade: Moderado
This guide will explain how to locate and replace the fan inside of the Asus X501A-RH31 laptop. This replacement guide will fix the cooling aspect of the computer.
Seções
Ferramentas
Ferramentas (continuação)
Passo 1 Fan  ¶
Unscrew the three screws using the Phillips #00 screwdriver.
Passo 1 Fan  ¶
  • Unscrew the three screws using the Phillips #00 screwdriver.
  • The three screws are 5 mm in length, 4.2 mm in diameter.
Passo 2  ¶
Unscrew the three screws on the left hand side of the big motherboard.
Passo 2  ¶
  • Unscrew the three screws on the left hand side of the big motherboard.
  • This will loosen the motherboard, which will allow for better access to the cables in the next step.
  • The three screws are 5 mm in length, 4.2 mm in diameter and Phillips head screws.
Passo 3  ¶
Remove the connector cable attached to the bottom of the motherboard. Take the black plastic spudger and press down on the lower half of the white plastic piece to remove the connector cable. Take the black plastic spudger and press down on the lower half of the white plastic piece to remove the connector cable.
Passo 3  ¶
  • Remove the connector cable attached to the bottom of the motherboard.
  • Take the black plastic spudger and press down on the lower half of the white plastic piece to remove the connector cable.
