Pular para o conteúdo principal
Ajuda
PowerBook G4 Titanium DVI Optical Drive Replacement
Guia em destaque
Guia em destaque
Este guia foi considerado super bacana pela equipe da iFixit.
  • Autor: iRobot
  • Dificuldade: Difícil
Easily upgrade to a fast 8x SuperDrive.
Passo 1 Optical Drive  ¶
Remove the 4 T6 Torx screws securing the modem and inverter boards to the optical drive.
  • Remove the 4 T6 Torx screws securing the modem and inverter boards to the optical drive.
  • Lift the inverter board off of the optical drive.
  • Lift the modem off of the optical drive, carefully guiding the orange cable through the metal mounting bracket.
Passo 2  ¶
Disconnect the orange optical drive ribbon from the back of the drive.
Passo 2  ¶
  • Disconnect the orange optical drive ribbon from the back of the drive.
Passo 3  ¶
If your new optical drive already has a bracket and bezel for your model, then you are done.
Passo 3  ¶
  • If your new optical drive already has a bracket and bezel for your model, then you are done.
  • Remove the 2 Phillips screws from the side with the longer bumper.
  • Remove the bracket from the optical drive.
Passo 4  ¶
Remove the 2 Phillips screws from the other side of the optical drive.
Passo 4  ¶
  • Remove the 2 Phillips screws from the other side of the optical drive.
Passo 5  ¶
Depending on the new drive's model, the bezel on your old drive may not transfer to the new one. The bezel is not strictly necessary, and the drive will probably work fine without it, but you should transfer it if you can in order to ensure proper alignment with the case.
Passo 5  ¶
  • Depending on the new drive's model, the bezel on your old drive may not transfer to the new one. The bezel is not strictly necessary, and the drive will probably work fine without it, but you should transfer it if you can in order to ensure proper alignment with the case.
  • Remove the 4 Phillips #00 screws from the top of the optical drive.
Passo 6  ¶
Lift up on the thinner edge of the optical drive so that you can access and depress the recessed black tab using a spudger.
Passo 6  ¶
  • Lift up on the thinner edge of the optical drive so that you can access and depress the recessed black tab using a spudger.
Passo 7  ¶
Use a spudger to depress and release the two black tabs on top of the optical drive directly over the bezel.
Passo 7  ¶
  • Use a spudger to depress and release the two black tabs on top of the optical drive directly over the bezel.
Passo 8  ¶
Use a spudger to depress and release the black tab on the left side of the optical drive.
Passo 8  ¶
  • Use a spudger to depress and release the black tab on the left side of the optical drive.
Passo 9  ¶
Carefully remove the bezel from the optical drive, minding the two plastic tabs on the bottom, which may catch.
Passo 9  ¶
  • Carefully remove the bezel from the optical drive, minding the two plastic tabs on the bottom, which may catch.
  • If you have a CD or any other object jammed in your optical drive, we have an optical drive repair guide.
