Ir para o conteúdo principal
eufy Security SpaceView Monitor Motherboard Replacement
O que você precisa
  1. eufy Security SpaceView Monitor Motherboard Replacement, Display Assembly: passo 1, imagem 1 %32 eufy Security SpaceView Monitor Motherboard Replacement, Display Assembly: passo 1, imagem 2 %32
    • Using either the Jimmy or the IFixit Opening tool, press into the opening notches built into the lower portion of the display.
    • The sides of the display each have two notches, while the top has 3 notches, and the bottom has 4 respectively.
    • Using the given tools, ensure that the tool enters the space of the opening notches, and apply force downwards, prying that specific part up and away from the housing.
    • Repeat for all sides and notches, until the display is completely detached from the rest of the monitor.
  2. eufy Security SpaceView Monitor Motherboard Replacement: passo 2, imagem 1 %32
    • Lift the display up and away from the housing.
    • Take care to not twist or pull on the ribbon connector.
  3. eufy Security SpaceView Monitor Motherboard Replacement, Screen: passo 3, imagem 1 %32
    • Lay the display face down on a table, to expose the back of the screen.
    • Use Phillips #00 screwdriver to unscrew each of the six screws that hold the display in place.
    • There are two on each end of the display, and one on each of its longer sides.
  4. eufy Security SpaceView Monitor Motherboard Replacement: passo 4, imagem 1 %32 eufy Security SpaceView Monitor Motherboard Replacement: passo 4, imagem 2 %32
    • Gently lift the display housing, and set it aside.
    • The housing is ready to have the new display installed.
  5. eufy Security SpaceView Monitor Motherboard Replacement: passo 5, imagem 1 %32
    • Gently disconnect the ribbon connector from the motherboard, taking care not to damage it.
  6. eufy Security SpaceView Monitor Motherboard Replacement, Motherboard: passo 6, imagem 1 %32 eufy Security SpaceView Monitor Motherboard Replacement, Motherboard: passo 6, imagem 2 %32
    • Using a Phillips #00 screwdriver, unscrew the 4 retaining screws in each corner of the motherboard.
  7. eufy Security SpaceView Monitor Motherboard Replacement: passo 7, imagem 1 %32 eufy Security SpaceView Monitor Motherboard Replacement: passo 7, imagem 2 %32 eufy Security SpaceView Monitor Motherboard Replacement: passo 7, imagem 3 %32
    • Starting with either red/black wired connector on, gently pull it from its receptor and set it aside.
    • Pull the white ribbon connector from the motherboard, on the side closest to the battery.
    • Lift the motherboard and disconnect the antenna connector from its port.
    • The motherboard is free from the housing and can be replaced.
Conclusão
ZFarley
Membro desde: 10/31/23
395 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2023 Membro de UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G5
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 13
Duração total: 77
