Ir para o conteúdo principal
enTourage Pocket eDGe E-Reader Screen Replacement
O que você precisa
  1. enTourage Pocket eDGe E-Reader Screen Replacement, Battery: passo 1, imagem 1 %32 enTourage Pocket eDGe E-Reader Screen Replacement, Battery: passo 1, imagem 2 %32 enTourage Pocket eDGe E-Reader Screen Replacement, Battery: passo 1, imagem 3 %32
    • Make sure the device is powered off before beginning.
    • Open the Pocket Edge and place device with the screens face down. The side containing the stylus should be on the left.
    • Remove all eight elliptical rubber tabs covering screws using your finger or spudger.
  2. enTourage Pocket eDGe E-Reader Screen Replacement: passo 2, imagem 1 %32
    • Using your J1 Phillips head screwdriver, remove all eight 6mm screws from the back of your device.
  3. enTourage Pocket eDGe E-Reader Screen Replacement: passo 3, imagem 1 %32 enTourage Pocket eDGe E-Reader Screen Replacement: passo 3, imagem 2 %32 enTourage Pocket eDGe E-Reader Screen Replacement: passo 3, imagem 3 %32
    • Using the plastic opening tool, lift the back plate from both sides of your device and remove them.
  4. enTourage Pocket eDGe E-Reader Screen Replacement: passo 4, imagem 1 %32
    • Locate the side containing the battery. Lift the top of the battery out using your finger and the indentation at the top.
  5. enTourage Pocket eDGe E-Reader Screen Replacement: passo 5, imagem 1 %32
    • Carefully unplug the bottom side of the battery from the connecting plug and set the disconnected battery aside.
  6. enTourage Pocket eDGe E-Reader Screen Replacement, E-Reader Screen: passo 6, imagem 1 %32 enTourage Pocket eDGe E-Reader Screen Replacement, E-Reader Screen: passo 6, imagem 2 %32
    • Locate the side of the device containing the motherboard.
    • Using your J0 Phillips head screwdriver, remove the three 5mm screws from the bottom of the motherboard.
    • Using your J0 Phillips head screwdriver, remove the four 3mm screws from the top of the motherboard.
  7. enTourage Pocket eDGe E-Reader Screen Replacement: passo 7, imagem 1 %32
    • Using the plastic opening tool, carefully pry the bottom of the motherboard up and away from the casing.
  8. enTourage Pocket eDGe E-Reader Screen Replacement: passo 8, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Position your device so the inside edge of the motherboard is closest to you.
    • Locate the three wires connecting the motherboard to the rest of the device.
    • Using your finger or a pair of tweezers, gently remove each of these from the motherboard.
  9. enTourage Pocket eDGe E-Reader Screen Replacement: passo 9, imagem 1 %32
    • Lift the outer edge of the motherboard up. Carefully disconnect the 3 connections on bottom of the motherboard by pulling gently.
  10. enTourage Pocket eDGe E-Reader Screen Replacement: passo 10, imagem 1 %32
    • The motherboard is now connected in only one place on the edge of the device. Being careful of this, flip the motherboard outside of the device, leaving it connected to the foam padding inside of the device.
  11. enTourage Pocket eDGe E-Reader Screen Replacement: passo 11, imagem 1 %32
    • Using your J0 Phillips head screwdriver, remove the one 5 mm screw holding the gray plastic e-reader screen backing into place.
  12. enTourage Pocket eDGe E-Reader Screen Replacement: passo 12, imagem 1 %32 enTourage Pocket eDGe E-Reader Screen Replacement: passo 12, imagem 2 %32
    • Carefully pry up the gray plastic e-reader screen using your finger and remove from the device.
Linha de Chegada
Adrian Do
Membro desde: 09/24/15
355 Reputação
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Duração total: 540
