Ir para o conteúdo principal
enTourage Pocket eDGe Battery Replacement
O que você precisa
  1. enTourage Pocket eDGe Battery Replacement, Battery: passo 1, imagem 1 %32 enTourage Pocket eDGe Battery Replacement, Battery: passo 1, imagem 2 %32 enTourage Pocket eDGe Battery Replacement, Battery: passo 1, imagem 3 %32
    • Make sure the device is powered off before beginning.
    • Open the Pocket Edge and place device with the screens face down. The side containing the stylus should be on the left.
    • Remove all eight elliptical rubber tabs covering screws using your finger or spudger.
  2. enTourage Pocket eDGe Battery Replacement: passo 2, imagem 1 %32
    • Using your J1 Phillips head screwdriver, remove all eight 6mm screws from the back of your device.
  3. enTourage Pocket eDGe Battery Replacement: passo 3, imagem 1 %32 enTourage Pocket eDGe Battery Replacement: passo 3, imagem 2 %32 enTourage Pocket eDGe Battery Replacement: passo 3, imagem 3 %32
    • Using the plastic opening tool, lift the back plate from both sides of your device and remove them.
  4. enTourage Pocket eDGe Battery Replacement: passo 4, imagem 1 %32
    • Locate the side containing the battery. Lift the top of the battery out using your finger and the indentation at the top.
  5. enTourage Pocket eDGe Battery Replacement: passo 5, imagem 1 %32
    • Carefully unplug the bottom side of the battery from the connecting plug and set the disconnected battery aside.
Conclusão
3 outras pessoas executaram este guia.
Adrian Do
Membro desde: 09/24/15
355 Reputação
Autoria de 3 guias
Um comentário
Great tutorial! I have two of these. Does anyone know where I can buy a replacement battery? I have looked everywhere. I would retrofit if I could find one large and flat enough. 7.2v 2000mA. Hate to have to trash them but they don’t make parts anymore.
Ron - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 19
Duração total: 1,449
