Ir para o conteúdo principal
Ajuda
Editando passo 33 —
Tipo de Passo:
Arraste para reorganizar
Pour a small amount of the plastic beads that were included with the kit into a heat- and stick-resistant container.
Use a heat gun to heat the plastic beads until they turn transparent.
Most hair driers are also capable of melting the beads. If neither a hair drier of sufficient power nor a heat gun are available to you, you can also try boiling them and straining them out of the boiling water.
When using a heat gun or hair dryer, be sure to turn the heat to high but leave the fan on low, or you will blow the beads out of the container!
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
