Ir para o conteúdo principal
Ajuda
Editando passo 12 —
Tipo de Passo:
Arraste para reorganizar
Solder the pins to the board on the printed side of the PCB.
Unsure of how to properly through-hole solder? Check out our technique guide. You can even use a thin piece of wire and practice with a hole on an unused trace.
Try to solder quickly and efficiently. Prolonged application of heat to any of the component pins can transfer enough heat to damage it.
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
