Ir para o conteúdo principal
Ajuda
Editando passo 5 —
Tipo de Passo:
Arraste para reorganizar
The power supply is attached to the upper case half with one 5.38 mm Phillips screw.
Use a #1 Phillips screwdriver to remove the screw and then remove the power supply.
Do not lose this screw. You will be using it to secure the new power supply to the upper case half.
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
