Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Loja
Ajuda
Editando passo 3 —
Tipo de Passo:
Arraste para reorganizar
Repeat for the second strip.
Hold down the battery as you remove the second strip, or the strip may fling the battery when it separates from the case.
If you removed both adhesive strips successfully, skip to step 27.
If either of the adhesive strips broke off underneath the battery and could not be retrieved, apply a few drops of high concentration (over 90%) isopropyl alcohol under the edge of the battery in the area of the broken adhesive strip(s).
Wait about one minute for the alcohol solution to weaken the adhesive. Use the flat end of a spudger to gently lift the battery.
Don't try to forcefully lever the battery out. If needed, apply a few more drops of alcohol to further weaken the adhesive. Never deform or puncture the battery with your pry tool.
Do not insert the spudger in the area between the volume down (-) button and the top edge of the battery, or you may damage the volume control cable lying underneath. Do not pry against the logic board or you may damage the phone.
For alternative methods to unstick the battery, continue with the next step below.
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
