Ir para o conteúdo principal
d.light Solar Lantern S2 Battery Replacement
O que você precisa
  1. d.light Solar Lantern S2 Battery Replacement, Battery: passo 1, imagem 1 %32 d.light Solar Lantern S2 Battery Replacement, Battery: passo 1, imagem 2 %32
    • To remove the lens, three T15 x 12.5mm screws must be removed by a T15 head screwdriver.
    • The location of the other two screws are marked in red.
  2. d.light Solar Lantern S2 Battery Replacement: passo 2, imagem 1 %32 d.light Solar Lantern S2 Battery Replacement: passo 2, imagem 2 %32 d.light Solar Lantern S2 Battery Replacement: passo 2, imagem 3 %32
    • After the lens has been removed the back cover needs to be removed. There are no snaps or screws holding it in place.
  3. d.light Solar Lantern S2 Battery Replacement: passo 3, imagem 1 %32 d.light Solar Lantern S2 Battery Replacement: passo 3, imagem 2 %32 d.light Solar Lantern S2 Battery Replacement: passo 3, imagem 3 %32
    • Take the battery out of its setting. It is only held in by friction (no snaps or screws).
    • Disconnect the battery by unpluging the white connector.
    • Install the new battery
Conclusão
5 outras pessoas executaram este guia.
Jeremiah Rhoades
Membro desde: 11/07/17
483 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team S2-G3, Harley Fall 2017 Membro de IUPUI, Team S2-G3, Harley Fall 2017
IUPUI-HARLEY-F17S2G3
3 Membros
Autoria de 6 guias
1Comentário do guia
thanks for this.
You didn’t mention the model/name of the battery replacement. Can you help with that?
Albert H - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 18
Últimos 30 dias: 67
Ao todo: 3,158
