Ir para o conteúdo principal
bObsweep Robotic Vacuum Battery Replacement
O que você precisa
Vídeo de Apresentação
  1. bObsweep Robotic Vacuum Battery Replacement, Battery: passo 1, imagem 1 %32 bObsweep Robotic Vacuum Battery Replacement, Battery: passo 1, imagem 2 %32 bObsweep Robotic Vacuum Battery Replacement, Battery: passo 1, imagem 3 %32
    • Unscrew the battery's cover plate on bObsweep's underside, above the main brush.
    • Lift the cover plate to expose the battery.
  2. bObsweep Robotic Vacuum Battery Replacement: passo 2, imagem 1 %32 bObsweep Robotic Vacuum Battery Replacement: passo 2, imagem 2 %32 bObsweep Robotic Vacuum Battery Replacement: passo 2, imagem 3 %32
    • Lift the battery up and out of its compartment.
    • Using both hands, pinch the plastic connector where the battery's wiring attaches to bObsweep and pull apart to disconnect.
  3. bObsweep Robotic Vacuum Battery Replacement: passo 3, imagem 1 %32 bObsweep Robotic Vacuum Battery Replacement: passo 3, imagem 2 %32 bObsweep Robotic Vacuum Battery Replacement: passo 3, imagem 3 %32
    • Connect the wires of the new battery. Push together tightly and it will lock in place.
    • Tuck the wires down inside the battery compartment on the right side.
    • Lower the battery down into bObsweep with the barcode facing up.
  4. bObsweep Robotic Vacuum Battery Replacement: passo 4, imagem 1 %32 bObsweep Robotic Vacuum Battery Replacement: passo 4, imagem 2 %32 bObsweep Robotic Vacuum Battery Replacement: passo 4, imagem 3 %32
    • Lower the cover down so it lies flat and the screw holes of the cover line up with those on bObsweep.
    • Reinstall the two screws removed in step one to secure the cover and battery in place.
Conclusão
A quick fix for bObsweep's power supply. Changing an old lithium ion battery for a new one ensures the vacuum will work longer with fewer charging breaks.
Uma outra pessoa concluiu este guia.
Tatiana
Membro desde: 06/28/14
737 Reputação
Autoria de 17 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 2,770
