Introdução
A simple fix for any screen issues on a bObsweep Pethair.
Video instructions:
O que você precisa
Vídeo de Apresentação
Flip Bob over and remove the 7 screws around which hold the cover together.
Remove the main brush. Unscrew the holder, and lift the brush out. Reminder: Keep this screw separate from the others so you can use it later to reinstall.
Remove three circuit plugs from the motherboard. Pinch the small white tab on the side of each circuit plug and pull straight up to release each from the motherboard.
1. On the bottom left corner: a small connector with red, black and white wires.
2. One thick white wire that attaches on the right side of the previous connector.
3. On the top edge of bOb’s motherboard: a wide multicoloured connector.
Place the cover aside and begin your repair.
Remove the four screws holding the screen in place
Lift the screen up and it will detach from the cover.
The screen and cover buttons will lift out together, leaving an open space for your replacement parts to fit into.
If you remove the infrared sensor, replace it in its space on the new cover so the black side will be on bOb’s outside.
Then, install all four screws for the LCD display. To finish off the repair, simply follow: Closing bObsweep's cover after repair
To reassemble your device, follow the guide for closing bObsweep after repair.
