Introdução
Guide for the removal and replacement of the communications board on the Zune Flash media player.
O que você precisa
Prior to disassembly, verify the hold switch is engaged to ensure the device will not turn on during the procedure.
If the device turns on while it is being disassembled it could cause irreversible damage to the device.
Remove the three screws (5.5mm by 3mm) from the backside of the Zune using a small Tri-Wing screwdriver.
3 outras pessoas executaram este guia.
