Introdução
How to remove the center frame from the Zune Flash 2nd Generation.
O que você precisa
Prior to disassembly, verify the hold switch is engaged to ensure the device will not turn on during the procedure.
If the device turns on while it is being disassembled it could cause irreversible damage to the device.
Remove the three screws (5.5mm by 3mm) from the backside of the Zune using a Y00 Tri-Wing screwdriver.
Be sure to put this set of screws aside since they are a different size than any other screws in the device.
Release the LCD connector ribbon by flipping up the black switch. This will disconnect the LCD from the device.
At this point the LCD screen should be easily separable from the device.
Pry up the memory board from center piece with a Zune opening tool and gently pull it off.
Uma outra pessoa concluiu este guia.
