Ir para o conteúdo principal
Zotac GTX 1080 Ti Mini Fans Replacement
O que você precisa
  1. Zotac GTX 1080 Ti Mini Fans Replacement, Zotac GTX 1080 Ti Mini Fans: passo 1, imagem 1 %32 Zotac GTX 1080 Ti Mini Fans Replacement, Zotac GTX 1080 Ti Mini Fans: passo 1, imagem 2 %32
    • Be sure to properly ground yourself with an anti-static wristband before working on the graphics card.
    • Use a Phillips #0 screwdriver to remove the two 4mm screws from the right side of the shroud.
  2. Zotac GTX 1080 Ti Mini Fans Replacement: passo 2, imagem 1 %32 Zotac GTX 1080 Ti Mini Fans Replacement: passo 2, imagem 2 %32
    • Use a Phillips #0 screwdriver to remove the two 4mm screws from the left side of the shroud.
  3. Zotac GTX 1080 Ti Mini Fans Replacement: passo 3, imagem 1 %32 Zotac GTX 1080 Ti Mini Fans Replacement: passo 3, imagem 2 %32
    • Look for the fan header located beside the 16-pin power connector.
    • Gently pry the fan connector apart from the header with a flathead screwdriver.
  4. Zotac GTX 1080 Ti Mini Fans Replacement: passo 4, imagem 1 %32 Zotac GTX 1080 Ti Mini Fans Replacement: passo 4, imagem 2 %32
    • Slowly and carefully lift the shroud off the heatsink.
    • During this step, make sure not to damage the LED connector that is still connecting the shroud to the PCB.
    • Flip the shroud along the top of the graphics card.
  5. Zotac GTX 1080 Ti Mini Fans Replacement: passo 5, imagem 1 %32 Zotac GTX 1080 Ti Mini Fans Replacement: passo 5, imagem 2 %32 Zotac GTX 1080 Ti Mini Fans Replacement: passo 5, imagem 3 %32
    • Remove the three 3 mm Phillips screws holding the fans to the heatsink with a Phillips #0 screwdriver.
    • Remove the broken fans.
  6. Zotac GTX 1080 Ti Mini Fans Replacement: passo 6, imagem 1 %32 Zotac GTX 1080 Ti Mini Fans Replacement: passo 6, imagem 2 %32 Zotac GTX 1080 Ti Mini Fans Replacement: passo 6, imagem 3 %32
    • Place the replacement fan on top of the heatsink with the screw holes aligned.
    • Screw the fans into place using a Phillips #0 screwdriver.
  7. Zotac GTX 1080 Ti Mini Fans Replacement: passo 7, imagem 1 %32
    • Reconnect the fan connector to its header.
  8. Zotac GTX 1080 Ti Mini Fans Replacement: passo 8, imagem 1 %32 Zotac GTX 1080 Ti Mini Fans Replacement: passo 8, imagem 2 %32 Zotac GTX 1080 Ti Mini Fans Replacement: passo 8, imagem 3 %32
    • Place the shroud back over the heatsink and screw it back into place using a Phillips #0 screwdriver.
Conclusão
Hopefully, your graphics card is fully replaced and completely working now.
Uma outra pessoa concluiu este guia.
Victor Pan
Membro desde: 01/27/21
175 Reputação
Autoria de 1 guia
Equipe
Um comentário
Do you know what size (diameter and thread) the 4mm and 3mm screws are?
cchagadorn - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 21
Últimos 30 dias: 75
Duração total: 4,856
