Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Flip the pony over.
Remove the five Triangle 3 screws from underneath.
Disconnect all of the wires between the head and leg sections.
To replace the power/volume switch, remove the two Phillips #0 screws from the switch.
Lift the switch out to replace.
Remove the black bar by unscrewing the two triangle screws marked in yellow. These screws are recessed into the black bar so you may need an extender for your triangle bit.
If you are not replacing the pony's speaker, skip the next bullet point.
Lift out the speaker, again making sure that it is disconnected, and replace with a new one.
