Ir para o conteúdo principal
Zoomer Show Pony Sensor Replacement
O que você precisa
  1. Zoomer Show Pony Sensor Replacement, Sensor: passo 1, imagem 1 %32 Zoomer Show Pony Sensor Replacement, Sensor: passo 1, imagem 2 %32 Zoomer Show Pony Sensor Replacement, Sensor: passo 1, imagem 3 %32
    • Flip over your pony and find the screws marked in red.
    • Remove these screws with a 3.0 Triangle screw bit. Don't worry about keeping them seperated because they are all the same size.
    • When the screws are removed the head and rear legs should be removable. Be careful to not pull everything apart to much because the head and legs are all connected to the motherboard.
  2. Zoomer Show Pony Sensor Replacement: passo 2, imagem 1 %32 Zoomer Show Pony Sensor Replacement: passo 2, imagem 2 %32 Zoomer Show Pony Sensor Replacement: passo 2, imagem 3 %32
    • Remove the wires connecting the head and leg sections. We will disconnect all of the wire connections in this step and they will need to be re-connected at the end, so be careful when disconnecting.
    • Now that the wires have been disconnected, the head and back legs should be free to place aside
    • Remove the black bar by unscrewing the two triangle screws marked in yellow. These screws are recessed into the black bar so you may need an extender for your triangle bit.
  3. Zoomer Show Pony Sensor Replacement: passo 3, imagem 1 %32 Zoomer Show Pony Sensor Replacement: passo 3, imagem 2 %32 Zoomer Show Pony Sensor Replacement: passo 3, imagem 3 %32
    • Take out the two clips keeping the motherboard in place but applying upwards pressure on them.
    • Remove the motherboard and replace. The sensors are soldered on to the motherboard so the whole board must be replaced.
Conclusão
Uma outra pessoa concluiu este guia.
Cedric Bossa
Membro desde: 10/02/17
118 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team S20-G5, Passmore Spring 2018 Membro de USF Tampa, Team S20-G5, Passmore Spring 2018
USFT-PASSMORE-S18S20G5
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 7
Duração total: 669
