Ir para o conteúdo principal
Zoomer Show Pony Power and Volume Switch Replacement
O que você precisa
  1. Zoomer Show Pony Power and Volume Switch Replacement, Power and Volume Switch: passo 1, imagem 1 %32 Zoomer Show Pony Power and Volume Switch Replacement, Power and Volume Switch: passo 1, imagem 2 %32 Zoomer Show Pony Power and Volume Switch Replacement, Power and Volume Switch: passo 1, imagem 3 %32
    • Flip the pony over.
    • Remove the five Triangle 3 screws from underneath.
    • The pony will separate into a few pieces once the screws are removed.
  2. Zoomer Show Pony Power and Volume Switch Replacement: passo 2, imagem 1 %32 Zoomer Show Pony Power and Volume Switch Replacement: passo 2, imagem 2 %32 Zoomer Show Pony Power and Volume Switch Replacement: passo 2, imagem 3 %32
    • Disconnect all of the wires between the head and leg sections.
    • To replace the power/volume switch, remove the two Phillips #0 screws from the switch.
    • Lift the switch out to replace.
Conclusão
Matthew Sutton
Membro desde: 01/25/18
278 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S20-G5, Passmore Spring 2018 Membro de USF Tampa, Team S20-G5, Passmore Spring 2018
USFT-PASSMORE-S18S20G5
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 677
