Ir para o conteúdo principal
Zoomer Meowzies Battery Replacement
O que você precisa
  1. Zoomer Meowzies Battery Replacement, Battery: passo 1, imagem 1 %32 Zoomer Meowzies Battery Replacement, Battery: passo 1, imagem 2 %32
    • Turn the Zoomer Meowzies over so it is on its back and its stomach is facing up.
    • Using the Phillips #1 screwdriver, loosen the screw holding the battery compartment closed.
    • This screw has a collar that will prevent it from being completely removed and therefore cannot be measured or replaced.
  2. Zoomer Meowzies Battery Replacement: passo 2, imagem 1 %32 Zoomer Meowzies Battery Replacement: passo 2, imagem 2 %32
    • Lift the compartment cover from the body. Due to the ribbon on the cover, the batteries should pop out as you remove the cover.
    • Replace with new batteries using the diagrams located within the compartment as a guide for correct battery orientation.
    • When replacing the batteries, weave the ribbon under each battery for easy removal later.
Conclusão
Mitchell Gentry
Membro desde: 02/14/18
675 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team S6-G2, Eyestone Spring 2018 Membro de USF Tampa, Team S6-G2, Eyestone Spring 2018
USFT-EYESTONE-S18S6G2
Membros da 3
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 8
Duração total: 854
