Ir para o conteúdo principal
Zoomer Meowzies Legs Replacement
O que você precisa
  1. Zoomer Meowzies  Legs Replacement, Legs: passo 1, imagem 1 %32 Zoomer Meowzies  Legs Replacement, Legs: passo 1, imagem 2 %32 Zoomer Meowzies  Legs Replacement, Legs: passo 1, imagem 3 %32
    • Using the Triangle driver remove the four 7.5 mm screws.
    • The two front screws are deeper than the two on the back legs which may cause difficulties. These can be reached by putting the bit in first then carefully putting the driver on slightly (not all the way)
  2. Zoomer Meowzies  Legs Replacement: passo 2, imagem 1 %32 Zoomer Meowzies  Legs Replacement: passo 2, imagem 2 %32
    • Turn the device so that the the device is on its side.
    • Hold the back and belly on the device and gently pull apart.
    • Pulling with too much force might damage a few cables inside, so caution is needed.
  3. Zoomer Meowzies  Legs Replacement: passo 3, imagem 1 %32 Zoomer Meowzies  Legs Replacement: passo 3, imagem 2 %32 Zoomer Meowzies  Legs Replacement: passo 3, imagem 3 %32
    • With insides exposed, grab leg and gently pull up and away from the body to detach them. Repeat for all legs needed.
Conclusão
Muataz Alahmadi
Membro desde: 02/14/18
193 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S6-G2, Eyestone Spring 2018 Membro de USF Tampa, Team S6-G2, Eyestone Spring 2018
USFT-EYESTONE-S18S6G2
Membros da 3
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 222
