Ir para o conteúdo principal
Zoomer Jurassic World Indominus Rex Nose Sensors Replacement
O que você precisa
  1. Zoomer Jurassic World Indominus Rex Nose Sensors Replacement, Mouth Part: passo 1, imagem 1 %32 Zoomer Jurassic World Indominus Rex Nose Sensors Replacement, Mouth Part: passo 1, imagem 2 %32
    • Flip the toy over to gain direct access to the first screws you need to remove for the replacement.
    • Remove the two (2) 7.5mm phillips screws using Phillips #1 screwdriver from the bottom of the jaw.
    • Remove the two (2) 7.2mm phillips screws using Phillips #0 screwdriver from the bottom of the jaw.
    • Gently remove the entire bottom jaw piece.
  2. Zoomer Jurassic World Indominus Rex Nose Sensors Replacement: passo 2, imagem 1 %32 Zoomer Jurassic World Indominus Rex Nose Sensors Replacement: passo 2, imagem 2 %32 Zoomer Jurassic World Indominus Rex Nose Sensors Replacement: passo 2, imagem 3 %32
    • Remove the 7.5mm phillips screw using Phillips #1 screwdriver from the middle of the tongue.
    • Using a spudger, gently pry the tongue out of the mouth.
  3. Zoomer Jurassic World Indominus Rex Nose Sensors Replacement, Nose Sensors: passo 3, imagem 1 %32 Zoomer Jurassic World Indominus Rex Nose Sensors Replacement, Nose Sensors: passo 3, imagem 2 %32
    • Carefully, pull out the circuit board that has the three nose sensors attached.
    • You're almost done! The only thing left to do is to use a soldering iron to remove the six (6) wires connected to the circuit board.
    • Use caution when soldering to avoid being burned.
Conclusão
Luke Selby
Membro desde: 01/20/16
624 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 10-3, Remmell Spring 2016 Membro de USF Tampa, Team 10-3, Remmell Spring 2016
USFT-REMMELL-S16S10G3
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 8
Últimos 30 dias: 8
Duração total: 342
